Can you identify a gap between those obstacles on the heading of the main cluster of towers that an antenna can "see" through? It might help to use the interactive map tool. Turn on the green lines, switch to satellite view, turn off the 45° view if it activates, then pan/zoom as needed and place the balloon various parts of your rooftop to provide reference lines towards the transmitters. If the trees and neighboring house are clearly visible in the aerial view, then you can usually get a very good idea of where might be the best mounting candidate locations using the virtual tools.
