Old 12-Jan-2011, 3:17 AM   #16
Originally Posted by mutton-javelin View Post
Do the colors on the terrain profile correspond to signal strength?
Yes, on the left side is the transmitter (the strongest signal) and as you move to the right, you see colors which represent progressively weaker signal strength. If there is obstructing terrain, you will see the shadowing effect of that terrain.
Run this tool for any of the station on your report, there will be a legend relating color and signal strength included in the output.
http://www.tvfool.com/index.php?opti...pper&Itemid=80
