Old 13-Jul-2015, 11:10 PM   #4
I was able to get 10-11 channels.
Actually, you only got 2 channels, WHPX ION, on real channel 26, virtual channel 26.1 and WFTY Tel, real channel 23, virtual channel 67.1. Each has sub channels, but they don't count as separate channels because they come from the same station. They are your strongest local channels.
You also have WTNH ABC on real channel 10, virtual channel 8.1, but your antenna isn't very good at picking up real channel 10. Yeah, I know it says " It's designed to capture both UHF and VHF signals (channels 2 to 69) while extending the reception range for all local HDTV broadcasts," but that's advertising hype.
Antennacraft indoor ultrathin antenna (MN:1500080)
http://comingsoon.radioshack.com/ant...l#.VaRFxDjbJLM
•20dB amplification provides a clear signal
•Omnidirectional antenna pattern provides 360° reception without hassle of adjustment
•Slim design can be wall mounted, used on the included stand or laid flat
•Designed for local broadcasts, up to 20 miles from transmitters
•Includes 6-foot coaxial cable and cable management
It is the real channel number that determines which antenna is suitable. The virtual channel numbers were carried over from the analog TV days to maintain the same identity they had.
Are you wanting to stay with an indoor antenna or can you go outside for better reception?
