Old 12-Jan-2011, 3:15 AM   #1
smsboodoo
Whats the best antenna choice?
I'm looking to dump my Comcast and move to OTA TV. It seems there are a fair amount of channels in my area, so I'm looking to maximize channel numbers, but I also want to maintain excellent reception. It appears that some channels are in high VHF, but most are in UHF. The two that are in VHF I definitely want. I live in an area that has visual to downtown Minneapolis, though there are houses and trees, but not very dense. I'm thinking I will probably mount the antenna about 15' off the ground, 20' max on the side of my house.
My plan is to have this feed all my TV receptacles(about 5) even though they will never all be used at the same time. Will I need additional amplifiers aside from the "injector" that some of these come with?
What would you recommend for an antenna on a budget of less that 100.00 including mounts, cables and amplifiers? I will install it myself so no expense there.
Here is the link from TVFool that I hope helps you help me...
http://www.tvfool.com/?option=com_wr...3cf4279e501aa1
Someone else recommended I buy the Winegard SS 200, which does seem like it would work.
Thank you for helping me out.
smsboodoo is offline   Reply With Quote
