Old 13-Jul-2015, 9:07 PM   #2
Welcome to the forum, Mike1953:
I am particularly interested in WALB and WFXL in Albany Georgia.
I don't think you will have much luck with them because they are very weak Tropo signals subject the whims of the weather, and they are blocked by the curvature of the earth that begins to affect signals at about 70 miles. If you click on a callsign in your TVFOOL report, you will see the terrain profile between the transmitter at the left and your location at the right. That black arc at the bottom of the profile is the earth.
The only solution I can think of is to have a friend in Albany stream it to you over the internet with a Slingbox.
I have an el cheapo amplified antenna bought for $20 from ebay on a 20' mast and am constantly having to change directions just to get the Tallahassee stations 40 miles away.
You shouldn't have that much trouble with them. Maybe we can do something about that if you are using one of those "150 mile" antennas; they have an internal preamp that is easily overloaded by strong signals. If you aim directly at Tallahassee and there is a problem, but if you aim away from Tallahassee and there isn't, that's overload.
