I think the trees and being in the attic are the bigger problems. You may have something in the shingles or the underlayment that is interfering with the Ch. 13 signal. Foil facing on some underlayment or insulation material is a common culprit.
You may have stated, but I haven't read the whole thread, why you can't go roof mount? Your test showed you can get it that way.
