Old 13-Jul-2015, 2:49 PM   #1
Marley
Help deciding on antenna(s) and Amp
Hello,
I am trying to figure out the best antenna setup to try. The more I read the more confused I become. I want to put up an outside antenna, be mounted at the top of my roof. I am thinking of possibly 2 directional antennas, one pointing NW and the other pointed SE, linked together. My goal is bringing in the networks consistently, but maybe I am asking to much. At this point do not want to put up a tower, trying to stay discrete as possible. Also trying to avoid using a rotor. Goal would be bringing in both FOX's, but would be happy with one.
Appreciate any feedback at possible solutions that might work for me.
I originally bought Antennas Direct DB4E Antenna thinking I could get away with an antenna in the attic, but soon realized that setup would not work. Here is my test system,
Antennas Direct DB4E Antenna, on a mast in the second story bedroom, pointed out the window
Winegard LNA-200 Boost XT Digital HDTV Preamplifier
The antenna is pointed NW, about 330 degrees,
Below are the links for the two maps, the 2 channels that are LOS, I actually do not care about.
http://www.tvfool.com/?option=com_wr...8e036210a2be30
http://www.tvfool.com/?option=com_wrapper&Itemid=90
Additional info,
My Location Elevation 520
Nashville Elevation 597
Paducah Elevation 341
Cape Girardeau Elevation 351
Here are the stations I can receive at the moment. As you will see only 6 is consistent and for the rest my only chance is the evening.
2.x wkrn 99 miles Nashville ABC, sometimes, SE
3.x wsil 59 miles southern Illinois ABC, in the evening, pretty consistent, NW
5.x wtvf 93 miles Nashville CBS, in the evening, 2 out 3 times, SE
5.2
5.3 thistv.
6.x. Wpsd. 44 miles Paduka NBC, always, night and day, NW
17.x wztv 92 miles Nashville FOX, in the evening, pretty consistent, SE
23.1 kbsi 79 miles Cape Girardeau FOX, in the evening, pretty consistent, NW
23.2 wdka 50 miles, in the evening, pretty consistent, NW
49.1 wdka 50 miles Paducah, myTV, in the evening, pretty consistent, NW
49.2 gettv
49.3
58.x wnab Nashville 92 miles CW, in the evening, pretty consistent, SE
Marley is offline   Reply With Quote
