Old 13-Jul-2015, 2:01 AM   #3
paul D
Thank you StephanieS,
The trees are a scraggly pine and a pretty full but shorter walnut. They are far enough away that they don't seem to be in the way, but that can be deceiving.
I'll look into the 2V with kit, thanks.
One thing I haven't figured out is how to power the splitter/ amp. The easy place to put the splitter is outside in the wall box but there's no power there. I'll have to pull wires from the panel nearby or make a penetration through the wall and the back of the box. Then plug in inside and run the cable through the hole to the splitter. It seems clugey but maybe that's how everyone does it.
I understand the cabling losses and thanks for the diagnostic tip. I really appreciate your help.
paul D is offline   Reply With Quote
