Old 10-Jul-2015, 4:20 PM   #5
This is one time I'm way more optimistic than rabbit73.
Thanks for the backup. I shouldn't make any posts right after an argument with my wife.
Originally Posted by Billbert View Post
Rabbit, I'm willing to experiment but was hoping somebody on this forum had experience with a signal profile like mine. I'm absolutely willing to cut and try different solutions but was hoping somebody had already been down a similar path.
Good; we will try to help you as best we can.
I'll be pretty busy moving in and won't have too much time to experiment
Understood.
Does your TV have a signal strength indicator to help you find the best location for your antenna?
I like the Diagnostics Screen on my Sony KDL22L5000 TV that shows relative signal strength, and signal quality as defined by SNR (Signal to Noise Ratio) and uncorrected errors.
bad signal; picture freeze, low SNR of 13 (should be > 15 dB), and high errors:
good signal:
My newer Sony 32R400A has a wider range signal strength scale with one dB steps; excellent for antenna experiments. It is also able to add a new channel after scan, so it isn't necessary to rescan after changing directions or antennas. I made a calibration chart of the signal strength scale with my Sadelco signal level meter that shows dBm values as listed on the TVFOOL report. See attachment 3.
