Old 9-Jul-2015, 5:55 PM   #13
Originally Posted by Ranchman View Post
Would that unit require an outlet? Close to the antenna?
Yes.
Power is need is at the splitter location for the "easy" version of the install. If you do not have a power receptacle within easy or convenient (<25' where you can simply run a coax line) distance, then you will need to use a remote power inserter and you can power the amp from one of the outlet locations where a convenient outlet is available. PCT sells a power inserter as an accessory. You can also use a sat/TV diplexer, it will work the same.
