Old 9-Jul-2015, 5:50 PM   #12
Ranchman
You could try replacing the 4 way splitter first. They are relatively inexpensive. For example the Ideal 4 way splitter at Home Depot or Lowe's is about $7.
If that does not resolve the problem then I second Greenish Apple's suggestion of the Channel Master (also sold as PCT) CM-3414 distribution amp to replace the splitter. You can pick them up for less than $35.
I have another 4 way 5-900 MHZ. Different than the new one from radio shack I was using I'll give it a try.
Ranchman is offline   Reply With Quote
