Old 9-Jul-2015, 5:47 PM   #11
Ranchman
Originally Posted by Greenish Apple View Post
Another thought about splitters, they split the signal, then split it again inside. So you have one outlet with -4db and the others with -8db. It could be that the other TVs are connected to the higher loss outlets.
Maybe a CM 3414 distribution amp would help instead of the splitter. It pushes the available signal to all TVs.
David
Would that unit require an outlet? Close to the antenna?
Ranchman is offline   Reply With Quote
