You could try replacing the 4 way splitter first. They are relatively inexpensive. For example the Ideal 4 way splitter at Home Depot or Lowe's is about $7. That could possibly resolve the issue if your old splitter has a defect. However, if the four way splitter is causing too much signal loss then I second Greenish Apple's suggestion of the Channel Master (also sold as PCT) CM-3414 distribution amp to replace the splitter. You can pick them up for less than $35 online. The home center stores usually have some other brands of amps available, but I think the build quality of the Channel Master is much better.
