Took the 40" downstairs and plugged into the very same cable the 60" is using and....same issue. The 40" gets garbled 32.1 and 32.3 but clean 32.2 upstairs and downstairs.
Hooked the 60" back up and 32.1; 32.2 and 32.3 all come in just fine.
The only variable is the tuner. The 60" uses a tuner with three (3) components (according to Samsung) while the 40" uses 1.
Wonder if the heat we've been having the last couple of weeks (when this started) is part of the issue? Again, if it was then the same issue would appear across all TV's and doesn't.
So...we are back to the tuners. Something is slightly different. Note: I have a Heidecker (BB's cheap brand) 32" in another room upstairs. It was doing the same thing as the 40". 32.1 and 32.3 breaking up and 32.2 fine. It uses a different cable outlet.
Bottomline: Must be tuner related.
