Old 8-Jul-2015, 9:15 PM   #3
After locating your subdivision, I don't think your conditions are all that severe (as long as the dam holds....). You're only about 75-150' below the blocking ridge about .3 to .5 mile away. Since you're only ~1° below the main lobe of the transmitter's beam, your signal powers will be very strong in your area, at least on the ridgeline to your south. This is one time I'm way more optimistic than rabbit73. Hey, NO TREES!
A modest UHF/high-VHF antenna should work fine. You'll very likely need to be patient about locating a final install point. You *might* need to go rooftop.
I wouldn't hesitate to go with something as small as a ClearStream 2V with a four-port distribution amplifier located in the basement.
Good luck!
