Old 8-Jul-2015, 7:18 PM   #6
The person at Samsung said that there may be a slight difference in the signal quality across 32.1; 32.2 and 32.3 which, when read by the tuner, causes the breakup on 32.1 and 32.3.
There shouldn't be any such difference across those sub-channels. The signal off the antenna, once decoded, is basically just packets of data with a header that identifies which virtual channel they belong to. It's not possible for only certain subs to be affected.
Might as well carry the 40" set downstairs and hook it up where the big one is at. That will tell you if there's a difference in the signal to the two sets.
