Couldn't find a factory reset option. Called Samsung and explained the issue. The 40" uses a less sophisticated tuner than the 60" does. checked the software and 40" is up to date. The person at Samsung said that there may be a slight difference in the signal quality across 32.1; 32.2 and 32.3 which, when read by the tuner, causes the breakup on 32.1 and 32.3.
going to take the 40" downstairs and plug it into the cable for the 60" and see if the issue is corrected.
