Old 8-Jul-2015, 5:37 PM   #2
Tim
If you are getting good signals from your current antenna to the closest TV, then maybe a new antenna is not your best option. Can you tell us a little more about how your system is set up? For example: Do you have a 4 to 1 splitter with a different RG6 cable going to each TV? How long is each run? Or do you have multiple 2 to 1 splitters? RG59 cable instead of RG6? Any way you can post a picture of the antenna? The more information you can provide, the better the responses will be.
