Old 8-Jul-2015, 5:26 PM   #18
TheNuke
Get a preamp on there and re-evaluate.
Thanks for all of the responses, I do appreciate it.
I'm trying to do all my homework and make the right call, so forgive me if I have it wrong, but I'm looking at the following pre-amps:
1. RCA - Low cost, ~16dB boost, low noise, not terribly tolerant to overload, lowest build quality
2. CM 7778 - Higher cost, ~16dB boost, low noise, good build quality
3. AD Juice - Higher cost, ~18dB boost, low noise, good build quality
I don't believe I'm anywhere near needing to worry about overload, even at the strongest channels.
Can I go wrong with any of those choices in a scenario in which my strongest signal is listed at 15.7 NM(dB), weakest at about 0 NM(dB)?
TheNuke is offline   Reply With Quote
