Old 8-Jul-2015, 4:35 PM   #1
Billbert
NW Denver HDTV recption experience
We're moving into a new house soon and are planning on OTA TV as a key element in our cable cutting program. We're in Broomfield and although only ~ 12 miles from the Lookout Mountain HD tower, we're in a low lying area (108th & Simms) with no direct line of site. Our signal map is here:
http://www.tvfool.com/?option=com_wr...f1f03054009d99
I'm planning on an attic antenna (15' elelvation) and there is a new run of coax from the attic to the home run box in the basement (25-30'). From there it will be split to 2 - 3 rooms in the house (another 20').
Question: Does anybody have experience with antenna selection from non-line of sight locations that are this close to the source? Per the signal analysis, there should be enough signal to pick up the locals, (ABC, CBS, NBC, FOX) which is all we need.
Any suggestions as to antenna selection? Amplification? I'd rather not go through several attempts at getting an appropriate configuration.
Thanks in advance.
Billbert in Broomfield
Billbert is offline   Reply With Quote
