Old 8-Jul-2015, 2:58 PM   #16
TheNuke
Please identify WHICH market you're aimed at and and also identify the stations by call letters & virtual channel, not network affiliation. Call letters are 100% unique network affiliations are not.
1. Wouldn't hurt.
2. Yes.
3. No. QS offers zero benefit for you.
4. Use the interactive tool (with the lines) in the SAT view mode for basic alignment. Tweak as needed using your signal quality or SNR meter, if equipped.
5. If you want to...
What is in front of the antenna?
The antenna is aimed toward the Green Bay market, 141-144 degrees.
WBAY, virtual 2.1, comes in fine, as expected as it is shown as 15.7 NM(dB) on the report
WLUK, real 11 (no virtual is shown) is intermittent at 13.5 NM(dB)
WPNE, real 42 comes in fine and is shown as 7.6 NM(dB)
WFRV, virtual 5.1, is intermittent like WLUK at 7.3 NM(dB)
WGBA, virtual 26.1, is as reliable as WBAY at 1.7 NM(dB)
There are tall trees starting 20' in front of the antenna, no obstructions of rooflines.
TheNuke is offline   Reply With Quote
