If this were me and I wanted all the greens and maybe a few yellows, I'd get a DB-8e and remove the reflectors. Then aim one panel at 190 degrees on a compass (which would also get the stations at 7 degrees and 352 degrees) and the other panel at 310 degrees (which would get the stations at 121 degrees. The VHF attachment can be added if you don't get the VHF channels with that antenna.
That's the luxury option.
You may first try an ANT-751 aimed at 190 degrees on a compass. You have a lot of stations in other directions that just might come in.
