Originally Posted by rabbit73
What tuner are you using?
How well does the Leaf work with the TV tuner vs the HTPC tuner?
Does the TV tuner or the HTPC tuner have readouts of signal strength or more important signal quality to help you position the antenna?
I am currently using a loaner AverMedia AverTV Combo PCI-E tuner card, with video output by a nice graphics card to my TV. If this all works out, I will eventually purchase some form of multi-channel tuner card so I can record more than one channel at a time. I have not compared the internal TV tuner with the card, but if the problem persists I may. But even if that is better I will need a solution because I need a DVR, so I cannot use the TV's internal tuner.
I will play around with tuner cards software and see if it has strength/quality readouts.
I appreciate the information, but a lot of this is well over my head. Based on the post about the Digital Cliff, it seems I may be just a bit off. Would you recommend a new antenna anyway? I don't want to put anything on the roof, and that clearstream seems like a monster for indoor use (I am not sure I could get my wife to agree to it). Are there other good options you can recommend?
I don't like computers, and have yet to find one that I would call user friendly. I only tolerate them for what they can do for me. I never have understood why anyone would want to watch TV on a computer instead of a TV.
For me, it is the least expensive and most versatile way to incorporate a DVR, without exorbitant TV guide fees or hardware limitations. Other than the reception, it was actually easy to set up and works seamlessly with my remote. The Windows Media Center interface is pretty well polished too.
The largest/oldest tree in my city covers this corner of the house. Believe me I wish they'd cut it down.
I assume trees are just something you need to work around with antenna placement.
