Old 7-Jul-2015, 5:20 PM   #14
TheNuke
If the channel is already programmed into memory but signal level and/or quality has dropped below the threshold for reliable reception, rescanning does not do anything useful (except occupy your attention until the signal conditions change and reception happens to return).
Thanks for the quick responses. If you were in my position what would your next steps be?
Right now my thought is that I will do the following:
1. Double-check the assembly/installation of the antenna
2. Install a pre-amp, likely the RCA suggested previously
3. Replace all cables with new QS RG6 (maybe they already are, I just don't know)
4. Double-check the aim with a magnetic compass
5. Rescan
TheNuke is offline   Reply With Quote
