Old 7-Jul-2015, 3:53 PM   #11
Depending on the day a re-tune may or may not pick up FOX.
An unnecessary and time-wasting exercise.
I suspect the tall trees on his property have filled in and crushed the signal a bit.
Happens every year. An amp might help a bit, but don't expect it to be a miracle cure.
the 10G201 is no longer made. Is the TVPRAMP1R my current best option? Are there other pre-amps I should consider?
Any medium or high gain, low noise preamp will likely work.
