Old 7-Jul-2015, 1:03 AM   #5
Billiam
Yes, the trees are probably the problem. I've run into this issue numerous times with various homes and apartments. As long as you can rotate the antenna, you should be able to find a good spot to overcome no signal or a weak signal due to the trees.
