Old 7-Jul-2015, 12:12 AM   #2
Move the antenna and try again. The "best" location would be stuck on a window that does not have energy film or a metal window screen and faces the broadcast towers without your neighbor's house, a big tree, or a forest in front of it.
Move the antenna away from the TV set as they sometimes self-interfere when the antenna is too close.
The bottom line is that the antenna will tell you where it needs to be, it doesn't work the other way (where you tell it that it has to work where you want it).
