Old 5-Jul-2015, 2:42 PM   #10
Dave_Calif
Hi,
I am thinking of doing this:
Get the 7698 and mount to the chimney. Where the Mohu is won't hold any of the Winegard antennas I don't think. When the Santa Ana winds blow we can get really bad winds, and I mean really bad. Put up maybe a 10 ft mast probably a 1 1/4 or bigger chain link fence railing. I figure get the best antenna and mount it solid.
Hold off on the preamp and see what just the antenna does. A question is would a preamp near the TV do much good? Since it has to be plugged in, that is really the first spot where it would be viable as where the cable enters from the roof, it is basically directly down to the TV.
Ground it all as you suggested earlier.
Thanks for all your help.
Dave
Dave_Calif is offline   Reply With Quote
