Old 4-Jul-2015, 6:45 PM   #8
Dave_Calif
Hi,
Sorry for the delayed response, I wanted to get up on the roof and take another pict to show you the actual direction. That big tree is the opposite direction behind where it is aimed.
I took another picture which is directly behind the antenna on the same horizontal height to try and give you a much better visual of what the antenna is pointing towards. I had to make them smaller to upload.
I could move the antenna to the chimney which is the second picture but it won't buy me much height than a couple feet. Plus then the wires are higher that the other current location since the wires are going downhill.
The TV is in the room right below the antenna with maybe 40 feet of cable and no splitters etc. I wanted to put it on the other end of the house which would be better, but that would increase the cable length by a lot and that concerned me.
I think the solution is a much better antenna so I am going to do some surfing and read up on the one you recommended. Maybe I should get a VHF one and use a switch depending on the channel?
Dave
Dave_Calif is offline   Reply With Quote
