					Originally Posted by  DougM
				Stereocraig: Were you measuring a short between the phasing lines and the boom too?  How did you track down which rivet was causing the problem, theres a bunch of them?
doug
 I'm sure mine was just one that slipped through, but you never know.
It is the vertical one all the way in the rear, the connects the flat phasing strips together.
Just pop the end cap to clip one of the meter leads to the boom and the other to one of the phasing lines. This will free up your hands to flex the assembly to check for intermittents.
