A wild guess, is that you live near the landfill.
You should be able to receive stations from Milwaukee, too.
I live near the drive in theater and receive tons of stations from both directions, as well as an occasional Michigan and Indiana.
The problem is, you would need a rotor, or a two antenna setup, w/ or w/out an AB switch.
If your tuner requires a full rescan every time you change directions, a rotor or an AB switch, is a no-go.
Barney Fife rocks!
