I had that same exact question, w/ the same exact antenna, a few years back.
A lady at Winegard told me, that the UHF section phasing lines DO in fact measure short between them.
The problem I had though, was that the rivet that connects them together through the boom, was rubbing on parts of the hole that hadn't been properly deburred, after being punched.
I drilled it out, replaced it w/ a bolt and put a couple layers of shrink wrap around the bolt.
