Old 3-Jul-2015, 7:18 PM   #1
MarcCharette
Do you think it's possible to get this channel?
Here's my report: http://www.tvfool.com/?option=com_wr...8e039f6fd92a37
I'm trying desperately to get CHCJ-DT because it has a lot of programming I want to be able to get. I can get every channel up to that easily. I have the antenna pointed as close as I can to 116 degrees.
Here is a street view of generally the way the antenna is pointed.
https://www.google.com/maps/@43.4637...7i13312!8i6656
Note that the apartment building is not in the way because obviously the antenna is mounted on my roof and not the road
My setup:
Antenna: Clearstream 2 (is actually a 2V but I removed the VHF antenna because the one nearby VHF station was too strong)
Pre-amp: Channelmaster 7777
Distribution amp: Some generic amp that adds +10db (I lose CITY-DT if I don't have this because I have it split 5 ways)
About 90' cable between preamp and distribution amp
I added the channelmaster 7777 last night and was able to get a CHCJ but it drops frequently/goes pixelated. Any suggestions for anything I can do to get it clear? I am not opposed to getting a different antenna or adding a second one if it will help
MarcCharette is offline   Reply With Quote
