Old 1-Jul-2015, 2:58 PM   #3
Welcome, amazin6:
Thank you for the new report. We were hoping for exact address or coordinates for the location (which will not show in the report) of your antenna, but we will try to work with a street level report.
I see a lot of trees in that area. I hope they are not in the signal path from 165 degrees magnetic.
Could I put an antenna on the existing direct tv pole after removing the dish?
Yes, if it is in the right location, is a strong satellite mount, and the antenna isn't too large.
What type of antenna do you recommend?
You will need a VHF/UHF combo antenna. It is the real channel number that determines which antenna is needed.
VHF-Low, real channels 2-6, you don't have any
VHF-High, real channels 7-13, you have 10, 7, 12, and 13
UHF, real channels 14-51, the rest of yours
The Winegard HD7694P might work for you. The 7697 is the next step up, but it might be too much for the satellite mount. Try it without the amp first to see what you get.
http://www.solidsignal.com/pview.asp...enna-(hd7694p)
Do I need an amp or rotor?
Yes, you will need a preamp or distribution amp depending upon how long the coax is from the antenna to the TV, and how many TVs you have. Your signals aren't very strong and many are 2Edge, which means the terrain between the transmitter and your location interferes with the signals.
The preamps to consider are the Antennas Direct Juice, Antennas Direct PA-18, Channel Master 7778, and RCA PREAMP1R. The Juice doesn't have an FM trap, but I don't see any strong FM signals in your area to cause a problem with TV reception. See the attachment for your FM Fool report based on your estimated location, because I don't know your exact location. The RCA is inexpensive, has some quality control problems, but you could buy 3 for the price of one of the others.
The best location for a preamp is close to the antenna. If the coax downlead is short and you have more than one TV you might consider an indoor distribution amp instead.
I don't think you need a rotor because your best signals are in the same direction, and it would probably be too much for the satellite mount.
Will I get the stations down to # 20 on the graph in red WSPF minus those that are not in the 160 degree range?
I'm not certain about WSPF; do you really want that?
https://en.wikipedia.org/wiki/WSPF-CD
I think your chances are good for down to WXPX ION.
Please let us know the results of your tests on this same thread.
