Is this another example of overloading?
Probably. Either that or the extremely strong signals were getting directly into the receiver's circuitry (ingress) and causing the image frequency reception. This is common on inexpensive receives that lack proper internal shielding.
You can also try an attenuator at the input to the receiver and see if the signal via the normal input can be cooled off, just like for the TV receiver.
