Old 30-Jun-2015, 10:56 AM   #12
Tell me about the FM filter and where I would put one?
Since you don't have a preamp (I hope) at the antenna, you can put the FM filter, or two in series for extreme cases, just before the CM distribution amp. All FM filters are not equal, so I needed to look at the frequencies of your strongest signals. This filter would be suitable:
Antennas Direct makes one, but it's not quite as good at the high end for WKQC 104.7.
Radio Shack also makes one, but it will not reject the signals at the low end of the FM band effectively (WFAE 90.7).
You can, instead, use a HLSJ to block all signals below channel 7, including the FM band. Use the common and high ports.
