Old 29-Jun-2015, 6:35 PM   #24
Flint Ridge
Junior Member Wannabe
Do you want it on both antennas? The GH6 is so much simpler so that run does not take long. Here is the VHF antenna, is this what you were looking for?
SWR
Gain across FM - looks like I shaved the freq off the bottom, should be enough to go by.
Basic Plots 80 - 90 - 100 - 110 Freq is in upper left corner. Front of antenna is to the right.
Guess I should start a run on the UHF and come back later and check it.
