Old 29-Jun-2015, 2:27 PM   #18
Flint Ridge
Junior Member Wannabe
On the UHF gain to the rear is higher by about 1 db. That would be in the general direction of the most powerful FM, at that freq of 92.3 I would be around 3.86 gain max, it will be off to the side of that, but I need to look at the max.
On the VHF, max gain is also off the backside and in this case it seems pretty blind to FM. Max gain projected on that signal of -10.5 The most it does is -8.51 around 80mhz at the rear.
My way of thinking is I need the filter more on the UHF antenna ahead of the amp, over the VHF.
Thanks again. Must say the 4nec modeling is kind of fun when you can check all the spec's out yourself.
Flint Ridge is offline   Reply With Quote
