Old 29-Jun-2015, 2:33 AM   #18
Jake V
Do the aiming of the antenna towards Buffalo before thinking about the amp.
Using a compass is best to aim to 147 degrees. But if you don't have one you can guess decently by going to http://www.tvfool.com/index.php?opti...pper&Itemid=90 and mapping your house again. Then switch to satellite, zoom way in, and click to "Show lines pointing to each transmitter". You can compare the green and red lines pointing to the transmitters in Buffalo to the landscape and figure out what direction to point it at. Good luck.
