It is necessary to post the image of the FM Fool report, that tool does not provide a means to linking to the report.
You'd also need to obtain specifics on the FM filter in the KT amp since there are no published data for it.
I've finally gotten high enough to get to 2 Edge vs Tropo.
Keep in mind at the TVFool modelling engine is ONLY an approximation and is based on data of limited resolution. There are inherent limitations in it that make the results of small changes in the input height pretty much an exercise in futility and that will probably make those results useful for entertainment purposes only. The real data comes when you actually put the antenna up in the air and probe at different levels to see what signal is actually there.
