But I did put a 50' coax through my window as a direct run from tv to antenna with no splitters as a test for wiring issues, I received the same channels with no changes.
You probably need to do that with the preamp at the antenna and its power inserter. Your UHF signals are calculated to be quite weak and a preamp is going to be mandatory. It's going to be a balancing act to select an amp that improves your system noise figure without causing compression or IMD from the strong, local signals.
