Old 10-Jan-2011, 5:25 PM   #2
Tower Guy
Originally Posted by crimso View Post
1.) i prefer to mount an antenna in the attic.
2.) prefer no amplifier (don't want to run power).
3.) really targeting the channels in the 90-180 degree range although getting 360 degrees without moving the antenna would be nice.
1. It might work.
2. If a preamp is needed, the power comes up the coax.
3. Your chances of that working reliably are 50/50.
Try an HD 7694P antenna. Pick it up at Solid Signal 25225 Regency Drive Novi, MI 48375.
If you need a preamp, the HDP-269 is the right choice.
