Thread: no uhf signal
Old 25-Jun-2015, 5:58 PM   #9
setup is using the old dish network
Did you remove ALL Dish-specific "splitters" or other accessories from the coax?
the amp block on the antenna
????? That doesn't make any sense..
into a splitter
Unless you're careful about what you use, splitters tend to block the operating power from getting to the amp which usually turns them into 30 dB attenuators (which means you won't get weak signals).
