At least two of your UHF stations *should* be strong enough to be picked up with a paper clip.
Make absolutely certain that the tuner is set to the proper mode and try that and see if you get anything on UHF 41 and 42. If the mode is set correctly and you do get those two stations, then you know you have a cabling or antenna issue. If you still get nothing, the results are inconclusive and further testing is recommended before assuming that there is a specific defective part.
