Old 24-Jun-2015, 4:54 PM   #12
MarkSB
I think your expectations are not realistic. Forget about the OMNI idea. If you want Baltimore, then a VHF/UHF combo needs to be aimed at Baltimore. If you want another direction, then you often must aim the antenna in that direction, or have a second antenna for that direction.
How would I combine the 2 antennas? I hunted around for diplexers a little bit, and most of them seem to be UHF/VHF. In this case I'd be trying to get UHF stations with both antennas.
MarkSB is offline   Reply With Quote
