Old 24-Jun-2015, 4:15 PM   #5
MarkSB
I agree with the suggestion by Jake V. We need to see a more accurate report because you want the Baltimore signals which are 2Edge signals from terrain interference. You can see the terrain path by clicking on a callsign in your report.
I was able to pull 2Edge signals at my last residence, but not so much here. I don't have much wiggle room for positioning either - it only seems to pick up signals on the one corner of the deck. I tried tilting it back at various angles, since that made a world of difference last time... but I'm still getting inconsistent results.
The channels I'm able to pick up now are (real channel #'s):
38 - good
8 - good
41 - good
30 - good
40 - bad
I was able to pick up more channels with it in the same position, but only in optimal conditions (one specific night, during late evening/after sunset). I can also get reception on channel 21 at times, even though the transmitter is on the other side of the building, and can get channel 47 if I point it t the E/NE. I should also mention, its a 3 story building so there's another level above me.
MarkSB is offline   Reply With Quote
