Old 22-Jun-2015, 6:17 PM   #16
frank55
frank55's Avatar
Channel Master 0089 or 94444 outdoor balun.
They have changed the design and I haven't tested the new version.
Some sellers are using the old image with the groove and wire ends with a hook. The new version has ring terminals.
https://www.google.com/?gws_rd=ssl#q...ng+transformer
I have a weather proof box, i can bring it close to the antenna if i could find a matching transformer with longer tape 300 ohm connectors,i can put it inside the box,i cold buy the smallest and best one available,
Since it brings so many channels connected strait to the antenna without matching transformer was thinking of getting 2 feet of 300 ohms dipole tape, i could make the connection inside the box and solder it to short peace of coaxial with a connector and connect to RF in amp ,what do you think,
if my antenna had good access i would try all this easier,but the antenna is on a 3 store apartment 50 feet high,and is an hassle to get up there,
https://www.google.com/search?q=300+...TsikUDuvM%253B
frank55 is offline   Reply With Quote
