Old 21-Jun-2015, 9:58 AM   #13
Billiam
If you want to combine a 7-69 antenna with a 2-6 antenna, you need the ZHLSJ, not the ZUVSJ.
If you use the UVSJ, then you end up with a device that combines 2-13 on the VHF port with channels 14-up on the UHF port which is not what you said you needed.
Just checked the combiner. It is the ZHLSJ on each one. I typed the wrong part number but actually ordered the correct combiner.
