Old 21-Jun-2015, 7:50 AM   #30
lspecski
Update, all is good, Rabbit 73, your plan worked with the Radio Shack Diplexer and the splitter. With a bit of movement of the Antenna, I am getting a 78% signal. The problem with my Samsung was that I had a bad connection with my coaxial cable which was ok transmitting the UHF signal but wouldn't transmit the VHF signal.
My only remaining issue but a very small deal is that I am getting WHYY PBS on the Olevia with a 68% signal, but not getting anything on the Samsung. But I get an alternate PBS out of NJ. I am going to buy a better splitter and may take the advice on a different combiner, but as of now, all is good.
Your idea to build the diplexer saved everything and I can't believe how simple it was.
lspecski is offline   Reply With Quote
