When I get a peak signal for FOX (69.1), then CBS (8.1) becomes choppy even though it's reporting strong peak signals.
That's because you need a VHF antenna pointed one direction but the UHF antenna pointed a different direction.
Well, that might explain a lot. I've run into a good (bad) number of reception issues on homes with solar panels where their inverters were to blame for causing RFI and disrupting reception. The closer the antenna is to the panels and the inverter, the greater the interference can be. Something to keep in mind.
